I've recently discovered that my application (done in C++ Builder) appears to suffer from a problem you fixed back in v1.3.1 of EditControls and was wondering if you'd be kind enough to tell me what you did?!
The fix in question is this one:
"- FIX: Drop descriptions didn't work as expected if the drag source was a 64 bit app."
In my own tool, when I drag from Explorer or something else 64bit, I get the nice big drag image ok but the description doesn't show up at all (even though the function to set it IS being called). Another odd thing is that I still get the old style cursors and not the newer looking ones with blue '+' or red '0' by the side of them (if that makes sense).
If I open 2 instances of my program and drag from an 'open file' dialog box, everything works perfectly... so it's just a 64bit -> 32bit issue like the one you appear to have had back in 2008.
I must also say 'Thank You' for your input to a thread about the Vista drag+drop stuff that I came across via a Google search (and to be fair, that's why I'm here asking for your help now). Without it, I'd probably still (months later) be searching for the info I needed!
Help with a fix you implemented back in v1.3.1 of editcontrl
LIGHTNING UK!
Re: Help with a fix you implemented back in v1.3.1 of editcontrl
I've changed many things on Aero drag images since I wrote the post you found with Google. But I'll have a look at the repository what I changed for EditControls 1.3.1.
Here's what I changed:
Then on DragEnter and DragMove, call this method (just before returning S_OK) with the dragged data object.
Hope this helps.
HRESULT InvalidateDragWindow(LPDATAOBJECT pDataObject)
if(!pDataObject) {
return E_POINTER;
HRESULT hr = E_FAIL;
FORMATETC format = {0};
STGMEDIUM medium = {0};
format.cfFormat = static_cast<CLIPFORMAT>(RegisterClipboardFormat(TEXT("DragWindow")));
format.dwAspect = DVASPECT_CONTENT;
format.lindex = -1;
format.tymed = TYMED_HGLOBAL;
if(SUCCEEDED(pDataObject->GetData(&format, &medium))) {
if(medium.hGlobal) {
#define WM_INVALIDATEDRAGIMAGE WM_USER + 3 // (wParam = 0, lParam = 0)
HWND hWndDragWindow = *reinterpret_cast<HWND*>(GlobalLock(medium.hGlobal));
GlobalUnlock(medium.hGlobal);
if(hWndDragWindow) {
SendMessage(hWndDragWindow, WM_INVALIDATEDRAGIMAGE, 0, 0);
hr = S_OK;
ReleaseStgMedium(&medium);
return hr;
Hope this helps.
