Bug:Multiline-Editbox which is readonly has a display error.
If you use a multiline editbox in readonly mode fill it with enough characters so the editbox needs to be scrolled. Now scroll down and up. The old characters to be erased from the display are displayed nonethless. Selecting the text erases them.
Re: Bug:Multiline-Editbox which is readonly has a display error.
I'll have a look at this problem in September. I don't have any time before. Thanks for your feedback.
I had a quick look at the problem. If you just scroll the control, it is redrawn correctly, but if it is scrolled due to text being appended through AppendText(), the problem occurs, am I right?
I will check that.
Hi Natorion,
Could you confirm what I wrote in my last post?
Sure.I will check it next week.
