Hello Tiku
I appreciate your work !! really it is great to use the unicode textboxes escpecially a nightmare in standart vb6.
I have one question to you , do you have also a unicode combobox control project ? maybe I missed this . or your updown textbox control can be used instead of a combobox somehow? I will be glad if you can share your experiences (or if you know any good one in another source can you advice me please) .
I couldn't understand why your site is not on top rank in unicode queries , I have been searching information,classes,samples and third party programmes about unicode since 1 week and finally I faced with your site ,I faced with very very garbage information !! really it is pity how sometimes google acts unfair !!
Please keep on your best work , your textbox control is far away front of microsoft form 2.0 text box control !!
Vielen Dank
Umut
Unicode Combobox?(thanks for your bests work!)
LGdesigner
I would love to finally write Unicode ComboBox and ListBox controls, but I don't have the time to do it. Unfortunatly this situation won't change for at least the next 4 months, sorry.
LGdesigner
LGdesigner
DataSource Property
Tiku
I started to change the text boxes in my project with the edit controls.
One problem I faced with the datasource property . With the standart and form 2.0 text box control I haven't taken any error
But with the edit control text box below synthax gave an error .
Set Text1.DataSource = rst
PS:rst is a New ADODB.Recordset defined Global
Do you have any idea or advice ?
The code fails because there is no DataSource property. I could change this, but don't know how to properly implement data binding support. Unfortunatly there's not much information about writing ActiveX controls in C/C++. In this case an additional problem is, that I've absolutely no experience with data binding. I never wrote a database application in VB6 (I guess this makes me unique :buck:).
So I have to disappoint you again: My controls don't support data binding. I'll try to find out how I have to implement this, but it will take time.
As I wrote, I have no clue about data binding. Maybe you could send me a small sample project which makes use of data binding?
Thank you for the sample project you've sent me.
It turned out that there was not much left to get data-binding working. Build 100 should help you.
Please report any bugs you encounter. I've reorganized parts of the code, so chances are good that I've broken something.
LGdesigner
Hello TikU
I have tested it , it works fineeeeeeeee !! Is this a official release of edit controls or under development ?. Can I use it safelly?
The day when you will release the unicode combobox will be my one of the best days in my life
I will wait your good news about adding new control unit .
Have a great day and please keep your good work !! Really it is impresive
Umut
Umut
It's more like a release candidate (RC). Chances are good, that I'll declare this version the official 1.2.1 release in ~3 weeks.LGdesigner wrote:Is this a official release of edit controls or under development ?. Can I use it safelly?
Compared to 1.2.0 I've changed quite a bit of the code, so I wouldn't be surprised if I've broken anything accidently. Therefore you should do thorough tests.
Thank you. I also wish you a nice day.LGdesigner wrote:Have a great day and please keep your good work !! Really it is impresive
Re: Unicode Combobox?(thanks for your bests work!)
It's been almost 3 years since you metioned it might be atleast 4 months before you make a combo and list box control that supported unicode?
Any idea if this will ever happen?
The control has been released more than 2 years ago. Have a look at the ComboListBoxControls in the download section.
