Hello,
I am using TreeView Control Version 1.13.2 and I want to sort (by name, by size, by date ....) the list of the file of the ListView on clicking the column header.
Is it possible? How can I do that?
Thanks
						Sort column
I'm not sure I understand your question right. You want to sort the items in the treeview by e. g. date, am I right?
There's a property SortingCriteria. Set it to the index of the column by which you want to sort. This index must be the same as the index that the namespace's IShellFolder2/IShellDetails implementation uses for the column.
Here are some default column indexes:
Another way might be to send a TVM_SORTCHILDRENCB message to the treeview and do the sorting all by yourself. This gives you full control, but requires more work and some understanding of how the shell works internally.
- 0 - Name
 - 1 - File size
 - 2 - File type
 - 3 - Last changed on
