Hello TiKu,
your unicode-capable control set is a great collection!
Thank you for them!
I was also looking for a unicode label control (my application is translatable by the user), and found the FlatButton control, with it's BorderLayoutModel = blmNeverShowBorder setting. Perhaps you could say alrady in your "What is FlatButton" post, that it is also a replacement for the simplest control.
    Zoltan
						Label control
Sorry to say this, but FlatButton isn't Unicode-capable.
A label more or less is for displaying text only. It shouldn't be that difficult to do the same task with Unicode support. Have a look at the TextOut API function.
Something like this should work (not tested):
If you need a more powerful function, you should use the DrawText API function:
Private Declare Function TextOut Alias "TextOutW" Lib "gdi32.dll" (ByVal hDC As Long, ByVal nXStart As Long, ByVal nYStart As Long, ByVal lpString As Long, ByVal cbString As Long) As Long
Dim s As String
s = "Hello World " & ChrW(&H30A1&)
TextOut Me.hDC, 0, 0, StrPtr(s), Len(s)Code: Select all
Private Declare Function DrawText Alias "DrawTextW" Lib "user32.dll" (ByVal hDC As Long, ByVal lpString As Long, ByVal nCount As Long, lpRect As RECT, ByVal uFormat As Long) As LongCrunching for Fab36_Folding-Division at Folding@Home. Join Fab36/Fab30! - Folding@Home and BOINC
