How to select entries in ListBox in SingleSelect Mode?
The place for threads about TimoSoft ComboListBoxControls
Rucksacktraeger
Post by Rucksacktraeger »
I could select an Entry this way:
LstU.ListItems(3).Selected = True 'Markiert Item 4
but why only in MultiSelect Mode? If I am not in MultiSelect Mode, how can I select Entries? With Select I mean to put the Caret on the selected position AND get the Background blue.
In MultiSelectMode 0 I get an error like this: Method 'Selected' for the Object 'IListBoxItem' failed (translated from german)
Btw: I tried the Unicode Listbox a lot and I played also with this:
MsgBox LstU.SelectedItem.Index '3
MsgBox LstU.ListItems.Item(3).Index '3
MsgBox LstU.CaretItem.Index '3
MsgBox LstU.CaretItem.Selected 'wahr
Re: How to select entries in ListBox in SingleSelect Mode?
Try this:
Set LstU.SelectedItem = <YourItem>
Rucksacktraeger
Thanks, that helped me!
This is my result for anyone with the same Problem:
MultiSelect = 1 or 2
'    Select
    LstU.MultiSelect = msNormal
    LstU.ListItems(5).Selected = True 'Markiert Item 6
'    Deselect ALL
    LstU.DeselectItems 'funzt nur bei MultiSelect
'    Deselect one entry ???
MultiSelect = 0
'   Select
    LstU.MultiSelect = msNone
    Set LstU.SelectedItem = LstU.ListItems.Item(3)
'   Deselect
    LstU.AllowItemSelection = Not LstU.AllowItemSelection 'Trick 17 to loose the Selection (the blue background)
Rucksacktraeger wrote:
LstU.ListItems(5).Selected = False
'   Deselect
Set LstU.SelectedItem = Nothing
Rucksacktraeger
this thread is quite old. But I have to change the old project and I ran again into the problem I had a couple of years ago.
I am in SingleEntry Mode and I can select an entry with this:
But I could NOT select a specific row (back than and now.)
LstU.ListItems(5).Selected = False will work in multi-selection mode only.
Rucksacktraeger
yeah, so is there really no chance to select a specific row by rownumber?
You can do this:
Set LstU.SelectedItem = LstU.ListItems(5)
Doesn't it work?
Rucksacktraeger
Wow. Thanks!!!
Ah, and to remove the selection, just set SelectedItem to Nothing.
