Customize item colors
I love the controls. I've been looking for a VB6 listview control that can handle the XP styles. I have found the themes & callbacks a bit confusing. My question is; how can I customize each individual subitems forecolor and backcolor?
You can do this using Custom Draw. The following should work:
Also take a look at the "Fonts and Colors" sample.
Private Sub ExLvw_CustomDraw(ByVal listItem As ExLVwLibUCtl.IListViewItem, ByVal listSubItem As ExLVwLibUCtl.IListViewSubItem, TextColor As stdole.OLE_COLOR, TextBackColor As stdole.OLE_COLOR, ByVal drawStage As ExLVwLibUCtl.CustomDrawStageConstants, ByVal itemState As ExLVwLibUCtl.CustomDrawItemStateConstants, ByVal hDC As Long, drawingRectangle As ExLVwLibUCtl.RECTANGLE, furtherProcessing As ExLVwLibUCtl.CustomDrawReturnValuesConstants)
Select Case drawStage
Case CustomDrawStageConstants.cdsPrePaint
' tell the control that we want to customize item drawing
furtherProcessing = CustomDrawReturnValuesConstants.cdrvNotifyItemDraw
Case CustomDrawStageConstants.cdsItemPrePaint
' TODO: Change TextBackColor and TextColor to make the whole item (listItem) appear in these colors.
' tell the control that we've changed the colors and want to customize sub-item drawing
furtherProcessing = CustomDrawReturnValuesConstants.cdrvNewFont Or CustomDrawReturnValuesConstants.cdrvNotifySubItemDraw
Case CustomDrawStageConstants.cdsSubItemPrePaint
If listSubItem.Index > 0 Then
' TODO: Change TextBackColor and TextColor to make the sub-item (listSubItem) appear in these colors.
' NOTE: Sub-item 0 is the item itself.
End Select
You need the GroupCustomDraw event to do this.
I'm not sure whether it's really possible to draw your own gradient, but chances are good. Probably the largest problem is to calculate the gradient's position. Unfortunately I've found no way to tell the underlying SysListView32 window to simply use a custom color to draw the gradient.
Private Sub ExLvw_GroupCustomDraw(ByVal Group As ExLVwLibUCtl.IListViewGroup, textColor As stdole.OLE_COLOR, Alignment As ExLVwLibUCtl.AlignmentConstants, ByVal drawStage As ExLVwLibUCtl.CustomDrawStageConstants, ByVal groupState As ExLVwLibUCtl.CustomDrawItemStateConstants, ByVal hDC As Long, drawingRectangle As ExLVwLibUCtl.RECTANGLE, textRectangle As ExLVwLibUCtl.RECTANGLE, furtherProcessing As ExLVwLibUCtl.CustomDrawReturnValuesConstants)
Const OPAQUE = 2
Const TRANSPARENT = 1
' NOTE: you must do this in the cdsPrePaint stage, not in cdsItemPrePaint
' change the group's text color
textColor = IIf(Group.ID = 1, vbRed, vbBlue)
' force the listview to draw the group text with an opaque background
SetBkMode hDC, OPAQUE
' now set the text back color
SetBkColor hDC, vbYellow
' set the font to use
SelectObject hDC, hFont
' tell the listview that we've changed the font
' we also tell it to NOT draw the gradient
furtherProcessing = CustomDrawReturnValuesConstants.cdrvNewFont Or CustomDrawReturnValuesConstants.cdrvNoGroupFrame
Case CustomDrawStageConstants.cdsPostPaint
' reset to transparent text background
SetBkMode hDC, TRANSPARENT
' TODO: draw your own gradient (should be possible using drawingRectangle and/or textRectangle)
End Select
