Hi Timo and Happy New Year!
Is something changed in "AlwaysShowSelection"? For me this is not working any more.
I can see "dots" around the row, but no "gray" backgrond.
Updated:
This is not working, when I click somewhere outside filled rows in listview, but works when lisview is loosing focus.
AlwaysShowSelection not working
Re: AlwaysShowSelection not working
Well, clicking on the background of the control deselects all selected items. As there is no item selected anymore, no item will be drawn with a blue/gray background. In which version has this been different?
Just ignore and delete this post
Sry
Sry
Silly question again
I click on item - carretitem is now the last clicked item
I click on the background of the listview, items are deselected, but the carretitem is still last selected/clicked item?
Yes, it is the same behavior as in Windows Explorer. If you want different behavior, you may handle the Click event and set the CaretItem to Nothing.
Thats what I did.TiKu wrote:Yes, it is the same behavior as in Windows Explorer. If you want different behavior, you may handle the Click event and set the CaretItem to Nothing.
Thnx
