ListItems.Tag?
ListItems.Tag?
For somereasons i can't use global variables and i have to save some save variables into ListItems.Tag to retrieve later. but in ExplorerListView there is no such thing like ListItems.Tag?
Is there any work around? like hiding the data in another column and hide it so it is not visible to the user or something?
Re: ListItems.Tag?
You can use the ItemData property of the ListItem class.
Re: ListItems.Tag?
In ItemData i can only add integer and long. but i can't add strings to itemData?
If you can give me an example please. reply fast please...
Re: ListItems.Tag?
A Long is sufficient to store ANY data. Changing it to Variant would increase the control's memory consumption significantly.
Here are three functions that can be used to store a string in ItemData:
Additionally you need to handle the FreeItemData event (don't forget to activate it):
And into the Form's Unload event you should put:
Now, for instance, instead of using lvItem.ItemData = 123, you call SetItemTag(lvItem, "123"). However, you should no longer access ItemData directly. Use the functions instead. Otherwise you'll run into memory leaks and crashes.
Private Declare Sub CopyMemory Lib "kernel32.dll" Alias "RtlMoveMemory" (ByVal pDest As Long, ByVal pSrc As Long, ByVal sz As Long)
Private Declare Function GetProcessHeap Lib "kernel32.dll" () As Long
Private Declare Function HeapAlloc Lib "kernel32.dll" (ByVal hHeap As Long, ByVal dwFlags As Long, ByVal dwBytes As Long) As Long
Private Declare Function HeapFree Lib "kernel32.dll" (ByVal hHeap As Long, ByVal dwFlags As Long, ByVal lpMem As Long) As Long
Private Function GetItemTag(ByVal lvItem As ExLVwLibUCtl.IListViewItem) As String
Dim pMem As Long
Dim s As String
Dim sz As Long
If Not (lvItem Is Nothing) Then
pMem = lvItem.ItemData
If pMem Then
CopyMemory VarPtr(sz), pMem, 4
s = String$(sz / 2, Chr$(0))
CopyMemory StrPtr(s), pMem + 4, sz
GetItemTag = s
End Function
Private Sub FreeItemTag(ByVal lvItem As ExLVwLibUCtl.IListViewItem)
If lvItem.ItemData <> 0 Then
HeapFree GetProcessHeap(), 0, lvItem.ItemData
lvItem.ItemData = 0
Private Sub SetItemTag(ByVal lvItem As ExLVwLibUCtl.IListViewItem, ByVal Tag As String)
Const HEAP_ZERO_MEMORY = &H8
Dim pMem As Long
Dim sz As Long
If lvItem.ItemData <> 0 Then FreeItemTag lvItem
sz = LenB(Tag)
pMem = HeapAlloc(GetProcessHeap(), HEAP_ZERO_MEMORY, sz + 4)
If pMem Then
CopyMemory pMem, VarPtr(sz), 4
CopyMemory pMem + 4, StrPtr(Tag), sz
lvItem.ItemData = pMem
Private Sub ExplorerListView1_FreeItemData(ByVal listItem As ExLVwLibUCtl.IListViewItem)
If Not listItem Is Nothing Then
FreeItemTag listItem
ExplorerListView1.ListItems.RemoveAll
Re: ListItems.Tag?
I am sorry i don't want such a long and complicated process just to store some string data into listitem.
Is there any alternative like adding a new column and hiding it from the user and use that column to add data to the listviewitem or something else?
I was usually storing info regarding the item into the item's tag. it was very easy process but unfortunately your listview lack tag
Re: ListItems.Tag?
Well, you asked for a solution and this is the solution that I recommend if you cannot avoid strings at all. It's pretty much the same as how C/C++ applications do it.ufo973 wrote:I am sorry i don't want such a long and complicated process just to store some string data into listitem.
Do you want to develop a software or do you want to hack things together? Using a "hidden" column for such purpose isn't anything that someone, who wants to call himself a software developer, would use. Also a column cannot really be hidden. If you set its width to 0, the user will still be able to resize it to any other width (as long as you allow column resizing).ufo973 wrote:Is there any alternative like adding a new column and hiding it from the user and use that column to add data to the listviewitem or something else?
Re: ListItems.Tag?
What is this? and how to activate it?TiKu wrote: Additionally you need to handle the FreeItemData event (don't forget to activate it):Code: Select all
Private Sub ExplorerListView1_FreeItemData(ByVal listItem As ExLVwLibUCtl.IListViewItem) If Not listItem Is Nothing Then FreeItemTag listItem End If End Sub
what happens if i don't put this in form's unload event?TiKu wrote: And into the Form's Unload event you should put:Code: Select all
Re: ListItems.Tag?
You activate the event by removing it from the DisabledEvents. You already did the same with the Click and DblClick events.ufo973 wrote:What is this? and how to activate it?TiKu wrote: Additionally you need to handle the FreeItemData event (don't forget to activate it):Code: Select all
The code that I've posted, reserves memory (using HeapAlloc) and copies the string that you want to associate with the item into this memory (using CopyMemory). Then it stores the address of this memory into the ItemData property. To retrieve the string from ItemData, the code takes the memory address stored in ItemData and copies the string that is stored at this address (again using CopyMemory).
Since the code reserved memory, it also needs to free this memory (using HeapFree) when it is no longer required - e.g. when the item is removed from the control. Otherwise your application will leak memory. This is done in the FreeItemData event. The FreeItemData event is raisded if any data associated with an item should be freed because the item is being removed.
When the form is closed, the list view control will be destroyed. However, the control cannot raise the FreeItemData event anymore, because VB6 already has reached a state during form destruction at which it no longer handles any events. And as I wrote above you'll need the FreeItemData event if you don't want your application to leak memory. Therefore you need to remove the list view items manually as long as the FreeItemData event still works.ufo973 wrote:what happens if i don't put this in form's unload event?TiKu wrote: And into the Form's Unload event you should put:Code: Select all
Re: ListItems.Tag?
Oh i got it now. thank you very much for explaining so well
