TextAlgin if style is Edit Field Only
Hi Timo!
Is it possible set TextAlign for combobox if style is set to Edit Field Only?
I'v tested with SetTextAlgin API, but this doesnt work
Alles gute;
Alles gute;
Re: TextAlgin if style is Edit Field Only
It should work if you call GetWindowLong(GWL_STYLE) for the hWndEdit window, set/remove the ES_CENTER/ES_LEFT/ES_RIGHT styles and call SetWindowLong(GWL_STYLE) to apply the changes.
Hi again
Dim lngStyle As Long
lngStyle = GetWindowLong(ComboBox1.hWndEdit, GWL_STYLE)
SetWindowLong ComboBox1.hWndEdit, GWL_STYLE, lngStyle Or ES_RIGHT
Does not work. Am i doing something wrong?
BR;
BR;
Hmm i think if control is created i cant change style anymore at runtime
For a normal Edit control the alignment styles may be set and removed after window creation. The combo box uses a normal edit control, so it should work. But it might be that the combo box prevents such changes to the edit control. If this is the case, you are out of luck.
Ha! I tried it myself. All you need is to force a redraw of the control after you changed the styles.
What you mean with "force redraw"?
SendMessage and WM_PAINT?
Calling Refresh should be enough.
Refresh does not help
Is my code correct in first post?
Assuming that you defined the constants and API functions correctly, it is correct, yes.
When I tried it myself on Tuesday, all I needed was to move another window over the control so that it will redraw. I thought that Refresh would be sufficient. Obviously it is not sufficient. Try this:
If this does not help, try this:
If this also does not help, you could toggle the Visible property twice, but then the control will flicker.
Call SetWindowPos(ComboBox1.hWndEdit, 0, 0, 0, 0, 0, SWP_NOSIZE Or SWP_NOMOVE Or SWP_NOOWNERZORDER Or SWP_NOZORDER)
Call SetWindowPos(ComboBox1.hWndEdit, 0, 0, 0, 0, 0, SWP_NOSIZE Or SWP_NOMOVE Or SWP_NOOWNERZORDER Or SWP_NOZORDER Or SWP_FRAMECHANGED)
Nope, nothing works
Does your application have Windows skins enabled? I tried on Windows 7 x64 with skins enabled. Maybe it works only if skinning is enabled (Windows loads a newer version of comctl32.dll then).
OK
It works with Win 7 but not XP
