New year, new controls. I finally finished the ButtonControls library. This is a library of 4 button-like controls: a frame, a checkbox, a radio button and of course a command button.
As usual there're 2 builds: Unicode and ANSI. The setup contains both builds, corresponding help files and 3 sample projects for Visual Basic 6.0 and C++/WTL. The Unicode version is the preferred one, but doesn't run on Windows 98/Me. The ANSI version runs on Windows 98/Me and on Windows NT 4.0/2000/XP/2003.
If you think you've found a bug, you may ask me for a Debug build, which helps you to locate mem leaks and crashes caused by the control.
Please use the ButtonControls forum for feedback.
[Download] [Online help]
ButtonControls 1.0.0
