Thank you
The place for discussions about this website.
rlvision
Thank you
Post by rlvision » 08 Oct 2009, 09:33
I just wanted to say that I am really impressed with your work! I was just about to give up VB6 and move to Delphi, but now that I found your controls I will need to reconsider if I should stay with VB6.
I will definitely donate if I start using your controls. Until then, let me encourage you by offering you free licenses for any application you might find useful that I have made, at http://www.rlvision.com
Just mail me and I'll send a license to you :D
Re: Thank you
Post by TiKu » 11 Oct 2009, 00:23
many thanks for this offer. However, while I'm sure your tools are great, I personally have no use for any of them.
rlvision
Re: Thank you
Post by rlvision » 09 Apr 2010, 09:49
Just to let you know, I just released my first program using your controls!
Hot Spot Studio: http://www.rlvision.com/spots/about.asp
This is a brand new app, so it was very easy to get started! My plan is to start using your controls in my old projects as well, but the conversion will take some time.
Re: Thank you
Post by TiKu » 09 Apr 2010, 16:20
Nice. For me it's always a pleasure to see great apps use my controls.
