Automatic plus/min detection
The place for threads about version 2.x of TimoSoft ExplorerTreeView.
Guest
Post by Guest » 01 Feb 2006, 16:28
Dear Timo,
Is it possible to have automatic plus/minus detection if a node has multiple children or if it has none ? I now have to manually check a node for plus/min addition or removal.
Kind regards,
Chris
Post by TiKu » 01 Feb 2006, 20:03
You mean adding a sub-item should automatically add the "+" and removing the last sub-item should remove it?
