SubItem Controls do not work on XP
Cube8
Post by Cube8 » 15 Aug 2015, 16:15
I just tried my application on Windows XP and noticed that in-place editing of subitems (i.e. embedded subitem control) does not work at all.
Is this a limitation of comctl32.dll in that OS?
I'm asking because I will likely have to support this OS. If there is a limitation, I will have to create a new UI for this case...
Re: SubItem Controls do not work on XP
Post by TiKu » 16 Aug 2015, 19:56
Hi, yes, this feature is not available on Windows XP. It is a limitation of comctl32.dll.
