StatusBar 1.0.0
This forum contains the news and their comments from the old, phpBB2+ based version of the website.
Locked
StatusBar 1.0.0
I've developed a StatusBar control. This time there's no beta phase, because the control isn't that complex and I'm confident that I didn't make too many mistakes. ;)
As usual there're 2 builds: Unicode and ANSI. The setup contains both builds, corresponding help files and 3 sample projects for Visual Basic 6.0. The Unicode version is the preferred one, but doesn't run on Windows 98/Me. Windows 95 isn't supported.
If you think you've found a bug, you may ask me for a Debug build, which helps you to locate mem leaks and crashes caused by the control.
Please use the StatusBar forum for feedback.
[Download] [Online help]
Locked
