How to populate a Combobox
The place for threads about TimoSoft ComboListBoxControls
bgygi
Post by bgygi »
Hi, I just downloaded your Combobox, which I am using in VB6. However, I am not clear how to populate the Combobox. The AddItem method doesn't seem to work with your control, and looking through the documentation I can't see what replaces it. I am trying to populate a Combobo with values from an Access table.
Thanks!
Brian
Re: How to populate a Combobox
the setup contains a couple of samples which also add items to the ComboBox.
The replacement for ComboBox.AddItem is ComboBox.ComboItems.Add.
bgygi
Post by bgygi »
OK< that worked, thanks!
I have another question: is it possible to enable the KeyPress event on Command Buttons? I see there is a flag for disabled events, but I'm not sure how to change it to allow Keypress events
Thanks again!
Select the command button in the Form designer, click it with the right mouse button and select "Properties...". This opens the control's property pages. To enable the keyboard events, remove the checkmark from the entry "Keyboard events" and click the "Apply" button.
