Cut, Copy and Paste
bjoernlueders
Cut, Copy and Paste
Post by bjoernlueders »
Is there a way to get control over the ContextMenu (cut, copy and paste) from "outside" (i.e. a menu)?
Re: Cut, Copy and Paste
What do you mean by "control", i. e. what do you want to achieve?
bjoernlueders
I want to apply an "edit"-menu with the items cut, copy and paste.
I see. Well, the context menu is provided by the system, so it's difficult if not impossible (I don't know a way to do it) to reuse it.
bjoernlueders
Sorry that I didn't google better at first:
http://www.devx.com/vb2themax/Tip/18632
Now it's working.
I knew about these messages, but didn't name them, because you still should check whether there is something to copy/cut/delete (i.e. there is text selected) or whether the control can handle the data contained in the clipboard and there are no messages like WM_CANCOPY or WM_CANPASTE. So these messages alone are not very helpful in my opinion.
