Some keyboard keys do not work in a User control
godeny
Post by godeny »
Hello TiKu,
I've placed your Unicode Edit Control into a User Control. It seems me, that the KeyDown event disappears somewhere inside for several keys. The RIGHT, LEFT keys do not function - do not move the insertion point. If i define the KeyDown event, it does not fire. But for other keys - PGDN, PGUP , for example - it works correctly, the event fires.
If the Edit control is placed directly on the form, then - of course - everything is O.K.
Zoltan
which version of EditControls are you using? The bug should have been fixed in version 1.1.0. I can't reproduce it with this version.
If it still exists, please provide a small test project which I can use for debugging.
Bye
godeny
Post by godeny »
Sorry, i've checked this forum, but not the download topic.
It was 1.0.2 from August 2007.
Now I've downloaded 1.1, and it works correctly.
Thank you.
Zoltan
